Need Help Getting 1G started...ECU?
jgr203
81
Oct 5, 2005
Seattle, Washington
1992 Eagle Talon TSI AWD
So I replaced my ECU with an Ebay ECU (used).
So I do not know if it even works! Is there any way that I can test it?
Im getting no spark.
Engine cranks, cams turn.
I am thinking about doing the manual diagnostic test with a volt meter.
Will this tell me what is going wrong?
Does anyone have any other suggestions, what all should I check?
Thanks again
I will give update tomorrow after I try everything I am suggested to do.
Turbo cars (awd & fwd) from years 1991-1994 all use the same ECU, not sure about automatics though...you should really try to make sure you know what ecu you need to buy before you actually buy one.
yes, I know what ECU I need
I want to know if there is a way to troubleshoot my car before I make a $300 investment
Plug in a logger (if you have one) and see if the ECU is responding to inputs properly. Make sure you are getting spark/fuel and that you don't have any vaccuum leaks.
check the 3 fuses on the positive battery terminal if the one 20a is bad thats why it wont start had the same problem with my laser replace if bad and your car should start :thumb:
Checked the 20A fuse its fine.
I am not getting any spark.
Is there a simple way to check my CAS?
