ECMlink Need help finding the problem
CDgr97GSX
162
10
Feb 11, 2009
Romania, Europe
Hello guys! I need some help finding the problem I got out of nowhere. Looking at the logs it seems when the ECU is going in open loop it cuts the injectors. I'm not sure if this is the problem but the car is hard to drive, engine is stopping while driving.
The settings in ECMLink are the same settings I used before and the car was OK to drive and no modifications were made in the meantime. Only thing I did was to install a new AGM battery and it's worth mentioning the car stayed in the garage for few months without a battery.
I know the VE map needs more work and I wanted to get someone to remote tune my car but I wanted first to fix a problem I have with a fluctuating fuel pressure. All the settings in ECMLink were made, long time ago, by a guy I paid to remote tune my car but unfortunately he stopped answering to my emails before the job was done.
Long time ago I did small changes on VE table using the SD VE Adjust (CombinedFT) and dialed in the new FIC 1650 injectors. Thank you!
