need help fast [coolant leak]
brandons 95
95
Jan 13, 2006
deltona, Florida
Ok I just put my new boost controler on and i was trying to set the boost when i stopped to adjust it i noticed antifreeze coming from under the engine i pulled the intake off to see where is coming from i have the evo 3 16g and the bracket that mounts the wastgate actuator to the turbo is hitting the line that runs under it to carry antifreeze the bracket is rubbing that hose and caused it to come off and i cant get it back on because of that bracket i noticed there is another hole on the bracket that holds the acuator can i move the bracket to that hole or how can i fix it (thanks)
Wow, from what I deciphered from that jumble you need a new line. If it is the rubber one I think it is I would just replace it with one about 1/2" to 1" longer. This will then give you slack and it will no longer be rubbing on the wastegate actuator.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
