ECMlink need help cars knocking at 5+
95eagletalontsiawd
61
Mar 11, 2012
Norwood, Missouri
the other day coming home from work my car made a really loud bang noise kind of like a backfire and my engine light flashed on and went back off and i lost power but it instantly kicked back in, and i pulled over and didnt hear or see anything wrong so i drive it home, past week no problems then yesterday it started losing power and my engine light would flash on and back off at around 3-4k rpm but no bang or noise. so i did a log and had knock and knocked up to 5.3. so is there something wrong with the motor or is it a tuning issue?
here it is
Bolt-on Modifications:
evo 3gt 16g turbo with internal wast gate 15psi, magnaflow full 3in exhaust, cat delete, 4in magnaflow muffler, greddy fmic intercooler, 1g crushed bov, fic 950cc injectors, walbro 255 fuel pump, k & N airfilter,
Engine Management:
dsmlink v2.5 , eprom ecu, afr guage, boost gauge, greddy turbo timer, mbc
Engine Internals:
6bolt swap, 6 bolt rods and pistons, arp head studs, ported and docked head, 5 angle valve job, bc titanium springs and retainers, crower 272 cams, acl race bearings rod/main, bse kit, ac delete
Drivetrain Modifications:
act 2600 pressure plate and clutch, solid one pice driveshaft, megan racing short throw shifter , symborski shifter bushings,
Suspension Modifications:
tokico illumin 5 way adjustable shocks, frount strut bar, full pollyuethane bushings,
Pm my1gdsm for good priced and power remote tunes for your speed pleasing. If need be on your own check this link out you can use v3 software with version 2.5 I would recomend upgrade to 3.0 v3 its rather cheap to upgrade with them. http://www.dsmtuners.com/forums/articles-tuning-ecu/448002-tuning-ecmlink-v3.html Also check this link for things needed done before start tuning http://www.dsmtuners.com/forums/ecmlink-tuning-log-file-advice/443297-please-read-before-you-ask-ecmlink-dsmlink-log-advice.html
