Need help Car wont Sart
95eagletalontsiawd
61
Mar 11, 2012
Norwood, Missouri
ok i have read almost all the no start forms and cant fix it i bought a 95 tsi awd 6bolt swap with a spun rod bearing pulled motor put new cranck n bearings in then cleaned every thing to get metal out put it back together put in car pluged in every thing right and wont start cranks but no start. iv checked timing correct its at 5.2 dec according to dsmlink, ect around 52 deg when checked, batery is charged, compression is 150,150,150,140, dont think its ecu because dsmlink works fine, its getting spark. it will crank and i can smell fuel and take the plugs out and coverd in gas.:banghead:
here is mod list if it helps
Modifications:
sbr g60-1 turbo, magnaflow full 3in exhaust, 5in magnaflow muffler, magan racing test pipe, internal wast gate, supra smic intercooler, 1g bov, pte 950cc injectors, walbro 255 fuel pump
Engine Management:
dsmlink , eprom ecu,
Engine Internals:
manley I beam rods, ross 8:5:1 pistons, metal mls headgasket, arp head studs, ported and docked head, 5 angle valve job, bc titanium springs and retainers, crower 272 cams,
Drivetrain Modifications:
act 2600 clutch and pressure plate, full pollyuethane bushings, solid one pice driveshaft, megan racing short throw shifter , symborski shifter bushings,
Suspension Modifications:
tokico illumin 5 way adjustable shocks,
pretty sure its getting the right spark and there hooked up right. i hav checked the ect like i said above dsmlink said it was 57 Deg when checked. and wouldent my ecu be fine if dsmlink works. i hve checked fuel pump to its fine. going to try no borrow a code reader tomarrow.
Make sure you battery power cable is fully connected. That was my problem.
o man, I havent been in dsmlink for about a year now and car is down for me to find out but its somewhere in there LOL look for something that says DTCs hope that helps LOL
On link go to ECU config (live)... and click then on the next page theres a bunch of buttons on the left hand side it will say fuel then timing and so on the go down where it says DTCs and click on that and it will pull up any codes that are present
