poppabear
- 113
- 1
- Apr 22, 2009
Dayton,
Ohio
Ok, i'll start from the begining ...
I bought a 95' Tsi awd from a guy in KY for $1500 with 180k
body mint
interior mint
The car jumped time due to tensioner failure.. Bent some valves ect ..
I bought a 1g head with good valves and put the valves in my 2g head ..
New timing belt, tensioner and component kit. Put the car in time at 0 deg.
Checked compression, at the time was at 150 across the board.
Bypassed BCS, with boost set at 14psi.
New plugs, NGK Platnium
New plug wires
Went to the track and ran a 16.00 flat in 1/4 mile
I knew right away something was wrong ...
I then installed the Evo 3 16G with the Punishment FMIC Kit, pushing 15psi (i haven't done the BLT yet, however holds strong at 15 at WOT).
Went to the track lastnight and ran a 15.61 ....
I'm totally disapointed in these times ...
I will post all other times on the slips in detail when i get home tonight, its kinda hard with the iphone
anyways, i need to know what things should i be checking out to figure out the issue..
I know it can be tons of different factors, but i need some advice from you pro dsmer's ...
I do believe my stock clutch is slowing me down out of the whole... Act 2100 coming soon.
Thanks in advance
body mint
interior mint
New plug wires
Thanks in advance
