need help asap
dsm_eclipse
May 26, 2004
warner robins, Georgia
98 gst i was going down the road yesterday driving normal not doging it out. came up to a stop light and could not get my car in gear. but when you turn it off and put it in gear and then crank it up it will move with the clutch to the floor. has anybody else had this happen to them before? i just replace the slave cylinder and put a steel braided clutch line on bout 2 months ago. NEED HELP ASAP please..........
Re-check your clutch fluid resivoir.
Also, did you bleed the system properly? There are some helpful articles in the DIY section of this site related to bleeding the clutch properly.
i dont need a diy. i know how to bleed a clutch and i put the slave cylnder on about three months ago. and the resivor was the first thing i checked when this happend any other suggestions
Your lack of being open to suggestions will not intice other to reply... :|
Bleed your clutch several times. Then bleed it some more. Just because you stopped seeing air on one release doesn't mean theres not still some in there. Check under your clutch pedal for fluid soaked into the carpet, also check the master cylinder boot for fluid leaks. If its leaking its time to rebuilt/replace it.
Also, drop the "better-than-thou" attitude; it won't get you far in this community.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
