Need Help Any Ideas
madracer247@aol
243
Aug 5, 2002
la, California
Well i just wanted to post this problem i had myabe you guys might now what it is well one day after i got my car out i took my friend around the block and he wanted to see a pull from 1st-3rd gear. I did so when i finished doing the deed at the end of 3rd almost i stopped, i noticed that the engine was reaving by itself like going all the way up to like 5k and stayed there like i was giving it gas. I was wondering if you guys might now why that is is it the tranny or did the throttle cable get stuck or something?Also i noticed that my car doesnt really like high rpm's and being over 90mph does that have anything to do Random Misfire cause i have that due to my 6 bolt swap ok any help will be thankful
Also when i go wot in 3rd or 4th sometimes as i go up in the rpm it goes and it just stops like it hits a wall and blows out a bunch of smoke i think its fuel but but i am only boosting like 13-14 what you guys think?
I say you need to look into dsm link since u have a 6 bolt swap. Check your throttle cable. Check for boost leaks and foul plugs.
