need electrical help!!
brisk42
Aug 7, 2006
oakland, New Jersey
Well finally worked out all the mechanical problems in the project car and now I'm onto the electrical, which i know jack sh@t about. If anybody is in north jersey and can spend a day in Oakland some time to help me out that'd be awesome, otherwise let me try and state my problems. These are my nonworking parts as of now, front blinkers, front/rear wipers, dash lights, rear running lights, rear license plate light, and well thats about all. Any ideas? I've checked continuity on the switches and they're all fine and cant find anything wrong at the lights or motors so I'm just plain stumped. I'd love to find it be something stupid just tell me what it is!!
Tom
first i would check all your fuses and relays, then go to the individual component control (ie: turn signal swith) and make sure it is plugged in and doesnt have any broken wires. if nothing than i would pull out a diagram and check for power at the controls with a volt/ohm meter,
fuses and relays were all checked and working properly, all switches and plugs under the steering column and checked and accounted for.... so I know it i is something after the column.... I'm sure its something simple like a difference between the 1gb and 1ga or something because I've tried matching them up in my swap but noticing the differences. Best thing would be having a stock 1ga that I can compare my setup to, any in north jersey wanna help?
