Need camshaft id guru help!!!!!!!!!
rarest_90_DsM
285
3
Jul 21, 2004
akron, Ohio
so my buddy bought this refurbished head off a guy for a 1g. puts it on the car we do the timing belt properly, dowels up all marks are perfect starts the car bad noises no compression. take the head back off only to realize the intake and exhaust are opening at the same time causing the valves to hit each other(Never saw this before) we start inspecting and the exhaust cam doesnt look right!!!! so i need help finding out what it is or out of. AND YES THE TIMING WAS DEAD ON!
exhaust cam marking starting at the sprocket 47 E16 2D S II
intake cam markings R4 08
thank you in advance Ive searched but to no avail HELP!!!!!!!!!!!!!!!
no i don't unfortunately. But i can tell you that one has a slit in it for the cas and the other one doesn't so it cant be 2 intake cams, unless one is out of a odd year 2g? couldn't be 2 exhaust cams either because of the slit? I can tell you that the exhaust cam looks like the actual shaft is thicker and made from a cast while the intake cam still looks cast but more refined
Turns out that when we compared the. Odd cam to a stocker its exactly the same except the lobe are 90 degrees off idk what this cam is out of
was thinking it may have been out of a 420a does anyone know if this cam would even fit?
Where did you get the cams?
the intake camshaft has the first set of lobes is just to the left of the timing pin, the exh is slightly to the right.
using the clock face as reference the intake cam is 1st set closest to the timing belt side is 1200 the second set of lobes are toward the 3 o clock location, the 3rd set are toward the 9 o clock location, and the last set are toward 6 o clock
the Exh cam is same location of lobes
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
