Razor_nl
- 73
- 0
- May 27, 2008
Noordwijk,
Europe
Sorry for bringing another clutch adjust topic but I've read a lot of topics about it, but none coveres my (simple) question.
When I swapped my engine I also swapped the clutch for an ACT2100. Since then, the (dis)engage point is really low on the pedal travel. Before it was just fine. It's like this
TOP
* (dis)engage
BOTTOM
Also it feels like the clutch isn't disengaging fully, it feels like it disengages just a bit, just barely enough to shift without grinding. Sometimes I can feel as I'm really "pushing" the gears in place, sometimes it kinda blocks when shifting at high revs, especially to 4th.
Anyway I found the page on TRE and RRE and I've read on how to adjust the rod under the dash.
So yesterday I went upside down and placed myself under the dash. Really uncomfortable position
I did find the rod itsself. I also found the bolt to adjust the top travel. But I have absolutely no idea which bolt is meant with "the lock nut on the adjuster rod" Also the photo on RRE didnt help me much. I do recognize a few things but it doesn't say where the lock nut is.
I was looking towards the rod when my head was somewhere near the gas pedal. I did see some bolts and those clamps somewhere around the rod. Or can't I see it when looking at it from this side and do I need to look from some other place? Or find it by hand only?
Before I'm starting to loosen bolts and such, I was hoping one of you guys could clearify a bit more which one the nut is I need to loosen.
TOP
* (dis)engage
BOTTOM
Loosen the lock nut on the adjuster rod and you'll be able to rotate the rod by hand. If getting the right free play off the floor makes it so that you loose the free play at the top of the pedal travel, you will need to adjust the upper travel stop. The upper travel stop is the cruise control switch.
