Nasty highway vibration, need help bad
spockmeat
Jul 25, 2006
Roanoke Rapids, North Carolina
:talon:
I have a 1995 Eagle Talon TSI AWD, and for some reason, after about 65mph on the highway, a vibration coming from the back wheels makes the whole back of the car vibrate. i cant tell exactly where its coming from, i just know its in the rear. when i press the gas pedal, it gets worse, when i release pedal completely, it doesnt COMPLETELY go away, but it does reduce some. i tried the same speeds in 4th gear instead of 5th and the same thing happend. BTW tire balance is good.
Why do you think your wheel balance is good? Did you get them balanced when you were experiencing this problem?
Maybe try an alignment, are your tires scalloped at all?
i had the tires balanced before i went to work today, didnt help at all. mabey allighnment, anyone else have any suggestions?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
