need clutch help asap. bad vibration
Talon7038
71
Feb 24, 2013
Pittsburgh, Pennsylvania
Ok so here is the deal. New xtd stage 4, oem tob, competion for and bal. New slave and master. Clutch w as perfect for 50 miles now get nasty vibration on and off at low rpm in neutral also. If I hold clutch in it goes away. Somebody help bc I am at a loss.
Unsprung yes and def torqued right. This is beyond chatter I mean the entire car will shake if you hold clutch in it goes away and if you get into higher rpm it settles
Not yet will have tranny out in a few hrs here. Will post what I find
There was a 1/4in gap between the clip and the tob. That quality control for you mitsu clips don't fit their tob.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
