Name that Flywheel
JBDdsmer610
508
8
Mar 4, 2006
easton, Pennsylvania
I am just wondering if this is an awd flywheel. i noticed the balancing holes not quite sure i have fwd flywheel it dosent have the holes ### let me know
Do you have a pic of the back side? 1G AWD flywheels had an additional weight ring cast into the back side to increase the weight. Later 2G AWD flywheels have a smoother flatter back side.
AWD pic below
FWD pic below
Pics and info from www.roadraceengineering.com
That's an AWD flywheel.
First of all, there is a wheight ring cast into it, second of all, FWD flywheel has bigger ring gear, which actually is bigger diameter then pressure plate mounting surface.
That's what I said. :p
