Dewayne Waldron
- 371
- 0
- Apr 5, 2009
Salem,
Virginia
I'm Turbocharging an NA 4g63 Eclipse. Could someone tell me what would be the best ECU to use. It's a 93, 5 speed NA, Turbo. (
sounds funny).
sounds funny).Follow along with the video below to see how to install our site as a web app on your home screen.
sounds funny).You aren't going to be able to run that much boost on the non-turbo pistons. The n/t tranny won't hold up long either. I blew third gear at partial throttle. Transmission always shifted fine but just one day . . . BOOM
Like everyone else says it's a fairly easy thin to do. Just wiring in the resistor pack, and running an additional 2 wires to the ecu for the knock sensor and mass air.
Another thing, fuel pump probably wont last long either
Edit: Sorry I see you mentioned running the turbo fuel pump. I actually don't recommend the upgraded clutch on the 7 bolt motor. Mine crankwalked 14,000 miles after i turbo'd it. I was running a ACT2600 N/t clutch setup
. Clutch? Yes get a better one, but make sure its for a n/t, and DO NOT worry about crankwalk, the chances of YOU(1gs in general) to get it is the same as ANY OTHER car.
