N/t Help Motor is Full of Fuel
Boosted2gGsX
Feb 9, 2005
Wallingford, Connecticut
Ok here is my problem well its my grls cars its a non turbo 2.0 n/t laser and well its completly filled with fuel. the car wouldnt start last friday and she cranked the piss out of it and now it would start i checked everything and found that the coolant temp senson was disconected. i pluged it back in and atempted to start it, it jsut clicked i went to the engine bay and saw fuel coming out of the intake and then i pulled the plugs and bam all 4 cylindders fulll to the top. I pulled the fpr and turned the key on and the fuel jsut kept pouring out is this normal...any help ide love it man thanks !!!
If it's really full of fuel the only way it could fill ALL the cylinders is for ALL the injectors to be stuck open. Determine if it's really all fuel. Maybe it's water AND fuel. Gasoline floats so it'll be at the top.
In any case don't try to start it full of fluid or you'll break a rod or a piston.
Rick - '91 GSX :dsm:
its all fuel and yes i already cranked it over with out the spark plugs in there wow nice giser show LOL
Ok man before you go any further and hurt yourself and your g/f's car. Pull your mpi fuse near the battery and remove the O2 sensor from the downpipe. Once you have done that unplug your cas, and crank over the car until at least almost all the fuel is out of the cylinders, then put new plugs in and connect the cas. Leave the O2 sensor out but still plugged in. See if the car starts. If it does then one of your problems is a plugged cat converter. If you don't have a converter then you have very very major mechanical problems....... While doing this test, don't blow yourself up...
