My RPM Problems (Video Inside)
paultheninja
179
Feb 5, 2008
Warsaw, Indiana
When my car gets a cold start, this is what it does. Sorry, its a cell phone video
<object width="445" height="364"><param name="movie" value="http://www.youtube.com/v/BDqy8O_F_CY&hl=en&fs=1&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/BDqy8O_F_CY&hl=en&fs=1&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="445" height="364"></embed></object>
It also instantly died on me twice before it would even go to that....once the engine gets a little warmed up it completely stops.
Check your biss. I had the same idle surge along with a dead isc but i replaced the biss and o-ring no more idle surge.
Same here if its cold out i have to 1st crank it for a couple seconds, then itll run for 1/2 a sec then die. It does this multiple times before i can get it running completely.
Those are signs of bad coolant temp sensor the one that sends a signal to the ecu, not the gauge one. My problem is also a fuel pressure issue.
check the following and i am sure your problem will be fixed:
1- TPS
2 ISC
3 BISS Screw
4- Coolant Temp sensor
5- check for boost leaks
6- check your injectors if they are not clogged by unplugging them one by one at a time and check for difference in idle.
7- ECU ( if it has leakage in the capicators) keep this as a last option after checking everything.
one of the above will be your problem.
please post back after the fix
cheers
