JLangevin
- 155
- 1
- Oct 14, 2005
Rialto,
California
Ok, so I have been searching here for weeks and doing various things to my 95GST forever trying to fix the various CELs I have been getting.... the most common one was the P0300 (Random Multiple Cyclinder Misfire) and apon searching here, found that many people here have been having the same problem... the CEL would come on, the engine would sputter, and you would have to either turn the car off and on to clear it, or let the engine drop to idle... The idle drop only worked a couple times... and I found myself having to put the car in neutral and restart it on the freeway to stop the misfire...
Since the P0300 codes, I got 2 more that all happened at roughly the same time including P0400 (EGR flow malfunction) and P1400 (Manifold Pressure Sensor Malfunction)- again, unable to be fixed including new EGR, solenoids and hoses... These codes would come on silmultaniously after about 15min of driving guarenteed... BUT... the other day, I had an alternator failure and since replacing the alternator, had no more rough idle, no misfires, and NO CELs in days...
Ive put roughly 100miles on the car with no CELs when before, I could get them when driving to the store... I saved myself money from replacing the Coil packs (which was my next step, even though they tested fine)....
So, I would reccomend checking your Alternator, since even small drips from the powersteering pump can kill yours. Thats what killed mine! I hope this info helps, and I am now installing a Volt Gauge to keep an eye on things a little better.
I hope this has helped someone!
