WOTDSM
- 167
- 0
- Dec 3, 2006
Detroit,
Michigan
Just a mild street setup that should be capable of +500HP w00t
~6 bolt block bored 1mm over (0.40), hot tanked, resurfaced.
~2g pistons, 1mm over sized
~ARP headstuds/cometic headgasket package from extremepsi.com
~Hastings 1mm piston rings
~Clevite P-series main bearings
~Clevite P series rod bearings
~Good crank, hasn't been polished.
~1g big rods that have the 1g pistons on them.
~Newish oil pan
~Balance shaft eliminator kit
All I need is a bottom end gasket set, a new water pump, an auto tensioner (partsdinosaur.com), and a timing belt kit (autozone ftw).
I'll be using this on the stock head, 14b, and stock fueling until my fundage increases then I'm thinking of going with a small 16g for its quick spooling characteristics, SAFC2, 550's, and a walbro 190 or evo FP. My only question is, should I be worried about crazy amounts of knock with the CR raised to 8.8:1? I already get pretty bad knock (mod list up to date in profile). Bad enough to melt a plug, I ran a can of seafoam through the tank but that didn't help, maybe I should get the 190 before the swap... LMK what you all think about this setup!
-Andrew
~Newish oil pan
-Andrew
