2G My left turn signal wont shut off
streetenvy
99
Mar 3, 2011
Port Charlotte, Florida
I was driving my GSX and I use the left signal and went to turn it off and it stay on even when it's in the off postion or right turn postion if its the switch where do I find it.
My bet would be that the column switch is stuck. If not, the flasher unit is near your radio. Remove your center console and you should see it pretty easily.
Pic of column switch. Remove the two screws and it comes right out.
Pic of the flasher unit. My interior is completely torn out but this should give you an idea of what to look for. Its on the right side of the console bracket above the ECU.
This happened to me before. There is a small plastic tab inside the switch that tends to break. My guess is that's it. The switch is easy to remove like stated above. A little pricey if you buy a new unit so might want to source a good working used one.
