Front left turn signal not working.
93Lzr
214
May 26, 2012
Grand Forks, North Dakota
Currently my front left turn signal is not working. The bulb is good but it's not getting power to the bulb. I was wondering if the relay is just for one signal or what. Or why else it could be?
Where did you check for power? Was it inside the socket or in the line? Sometimes they get corroded and will not allow power to the contacts. That happened to my reverse lights and had to just take the bulbs out and clan up the contacts. If that is not it, then maybe someone else will chime in and give better incite and I could learn something new.
People are just trying to help you sort this out. Have to tried to change out relays? Have you tried to trace the wires to see if it had been cut,corroded,etc.? Are you running higher than normal wattage lights? Just trying to throw somethings out there. Brainstorming.
I had a similar problem no problem to both parking lights, I just tapped into the wire from my turn signal wire, I have power now, it could be a simple short easy way I just found another power source problem solved.
