My idle issues have stumped me
girlieracr4g63
1,007
8
Nov 5, 2003
Kure Beach, North Carolina
Ok guys I need some ideas...Im having some crazy idle issues. Ive been over all the basic stuff. My ISC is unplugged, TPS is between 9 & 11%, FIAV is sealed off, throttle cable isnt sticking, Biss screw is set via v-faq..
The car idles around 1100 when its first cranked . Then idles down to around 900 when its warmed up. After about 5 min. of driving it wants to idle around 1900 and stays most of the time. Sometimes it will idle back down to 900, but most of the time it stays. I didnt start having these issues until I installed the FP2s..Im going to do a vaccum test today, but I wanted to see if anyone had any other ideas..
Thanks in advance
Wendy
You are driving around with the ISC un-plugged? :confused:
Keep in mind that cams will change idle...and if you have the exhaust cam retard 1 tooth you will loose more vaccum and make it even worse. Are you sure the timing is dead on?
