My First Road Racing event @ Streets of Willow Springs!
eclipsegsx1736
Supporting VIP
1,599
44
Nov 11, 2003
Los Angeles, California
Preparation
When I first got my GSX, over a year and a half ago, I didn't really know for sure what I wanted to do with it. My plans and wish lists changed frequently, but I for the most part thought I wanted a 12ish second car that also had decent handling. I, like almost every DSMer, wanted to upgrade the turbo before touching the suspension. I started to read and think more about it, and realized my true passion was in the handling, not so much straight line speed. I knew I had bought a car that could do both without too much trouble, although DSMs are known for power potential, not handling as much. So I set out to improve the handling before touching the turbo.
Since I still didn't know for sure what I wanted to do with the car, I knew I needed a pretty trick suspension setup, but I wasn't about to spend 2-3 grand on a JIC Muellerized setup from RRE, since I didn't have near the money, and I'm still in High School. I couldn't justify that kind of expenditure, even if that setup is pretty much as good as it gets. As some of you may know, I've been helping out Megan Racing to develop exhaust parts for our cars, and they offered me a nice discount on their coilover dampers. I did a lot of research on these coilovers, from people using them on various other cars, since almost no one has them on a DSM yet. They're essentially the same as the Apexi coilovers, made in the same factory. I have read countless good things about them from Evo owners, and they're generally harder to please in the handling department. Mind you they're no JIC or BuddyClub, but from what I read they work well for people that both street and track their cars.
I ended up purchasing the M-R coilovers, and, overall, I really like them. The only complaint I have is the spring rates, of which M-R is offering replacements. The included rates are 14kg/6kg which is a bit odd, but they said they work fine with 12kg/8kg or 12kg/6kg, one of the latter two I will run at the next track day (July 7th!!). I also bought a custom RRE rear swaybar with 3 adjustments. As instructed by RRE, I started on the lightest setting, which they say is still miles stiffer than stock (the bar is an 25mm, or an inch, thick). They guaranteed that I would spin on my first track day due to the swaybar (awfully reassuring). I picked up some Porterfield R4-E pads, which RRE says won't fade even to the point where the rotors start to glow. They weren't cheap, $150 for the fronts. During the breakin of the pads, I actually overheated and faded the rear MetalMaster pads, which I have had for a while, before the R4-E's up front. We all know the fronts get MUCH hotter than the rears, it just goes to show you how crappy the MetalMasters are for anything more than spirited street driving (I wouldn't even trust them on a hard canyon run).
I opted to run my street tires for the first day, it's much easier to learn to drive the car on street tires first, before going to R compounds. My next tire will be a 235/40 RA1. I have 17x8 wheels which I just got, so I reused my 225/45-17 BFGoodrich G-Force KDW tires that I used to have on the stock GSX wheels. (Just a side note, anyone planning on doing any kind of aggressive handling with a GSX, ditch the stock wheels before you touch the suspension, the wider wheel will make a bigger difference than anything especially for so cheap).
The biggest problem I later discovered at the track was with my camber settings. When I went to get my toe aligned to 0 all around, we took a camber measurement. On the left side, I had -1.25 in the front and -1.5 in the rear, not a good setup. The right I had -2.25 in front and -1.0 in the rear, which is more like what I wanted. I didn't think much of it then, but more on that later.
The track day, April 21st, was near the end of my spring break, so I had plenty of time to prepare. At 6' 2", I discovered that I couldn't fit in the car with the helmet on, even with racing seats. I ended up bolting the seat directly to the bracket, with no sliders, so I was able to fit with enough room, although if I sat completely straight up the helmet would brush the roof. I removed some of the interior, put some spacers under the hood to raise the rear to let air out, and ditched the passenger headlight for some extra flow and to keep the intake temps down for the intake sensor, since 84F and up pulls some timing. I also flushed the brakes and used some Valvoline SynPower Dot 4 which RRE recommended to me, it had a pretty high boiling point and it's cheap. The dry point was close to 500F if I remember right. The event started at 7:30, actual driving began at 9:00, and continued until 4:30PM or so. To take some of the pressure off, I decided to take the 1.5 hour trip the night before, and stay in a hotel.
Track Day!
Wow, that was a long intro. So I wake up and head down for breakfast, which was damn good for a free continental breakfast. :p It was only a 15 minute drive to Willow Springs (I ran at Streets of Willow). I arrive at the gas station to fill up right before hitting the track, the last thing you want to do is starve the fuel pump, so I kept it at ½ tank and above on the track. The first thing I realized was that my tire pressures were lower than I wanted. They were about 33 psi cold, I knew they would heat up a lot, but I wanted to start high to have some room to work with in either direction, since I planned on running ~39 psi hot. I arrive at the track and start unloading stuff, and head to the driver's meeting. I attended a track day a few months back, just to check out the action, and comparatively, this event was much more laid back. The driving will begin at 9:00, and there will be 2 run groups; one beginner group and one "advanced" group. After only one run each, the track will be completely open. This turns out to be an awesome idea, it never gets crowded, since there are maybe only 20 cars max, about half of them were Evos at least. Also, this time the track was set up in full-length mode, using the "bowl" turn, which had a 20 degree bank. After an overview of the flags and their meanings, the advanced group heads onto the track.
After about 10 minutes into the 1st run group, one of the blue Evos heads out a little late. He gets a few hundred yards, just past the 1st turn, and the car comes to a stop at the side. I couldn't see what the problem is. I was sitting in my car waiting to go onto the track, and the maintenance/emergency truck drives over to the Evo. A good 15 minutes go by, and finally the Evo is brought back into the pit, and I overhear that the wheel came off WTF. Apparently, a friend said he would finish swapping wheels/tires while the driver was at the driver's meeting, and forgot to tighten the lugs :|
The flag waved, and we were out on the track. A civic was playing pace car, and it was pretty heavily modded. The first thing I noticed immediately about the track was that it was much smaller than I expected. It was well laid out and a good size, especially for someone just beginning to road race. All the turns were 2nd and 3rd gear turns speeds from 30-70, and you only get up to around 100 max on the straights. The "bowl" turn had me worried before I got out there, but it ended up being my favorite turn. Right when you hit the apex, you can nail the gas and very slowly unwind the wheel as you power out of the turn, as the radius smoothly widens into a straight.
After only a few laps, I am already comfortable at the track, it's extremely fun. There's nothing to worry about, everything is going great, it's much less stressful and much more easygoing than I thought. I was quick to pick up the lines for the turns, and I spend the rest of my 80+ laps perfecting them. After about 10 minutes on the track, I come in to check out the car and the tire pressures, I didn't know how the car would handle this kind of stress. The pressure is already up to 41 psi, so I bleed it down to 38 and set out again. After another 20 minutes or so, the pressure was up to around 42 again, so I brought it down to 38-39 and it stayed there the rest of the day. I started out at about 13 psi and a rich tune, and later put some 100 octane in (just in case) and ran about 14-15 psi. The stock sidemount started to heatsoak somewhat, but the EGTs were in spec still.
I passed a few Evos, an M3 convertible, a Scion Xb :)rolleyes: , actually it must have been heavily modded because it wasn't so bad), and some others. There were obviously plenty of Evos out there that were faster than me, but I had the stock ones beat for the most part, and the lightly modded ones with "careful" ;) drivers. The uneven camber turned out to be VERY annoying. I was surprised how much of a difference 1 degree of camber makes. Most of the turns were to the right, since we were running the track CW, and I could feel the car didn't have enough front grip and too much in the rear. The opposite was the case, however, on left turns. The rear end kicked out if I trail braked, or let off the gas. This was much more fun, and more to my liking, since any oversteer could be tamed with the throttle, but the problem was that I was so used to the behavior during right turns. I would then enter a left turn as I would a right turn, and the rear end would start kicking out. If the car had even camber, one way or the other, it would be much easier to drive. I almost spun several times on the same left turn, but never completely spun out (take that, RRE! :D) I did manage to get _very_ sideways a few times, though. Throttle corrected it much better than counter-steering (which turned out to be a bad idea)!
Later in the day, one of the Evo drivers comes up to me during a pit, and asks for a ride. He says he's been watching me out there, and he wanted to see what it was like in a GSX. We went out a few laps, and he complimented me on my line, which was nice. I then hopped in his car (bone stock, just some Azenis and some brake rotors). It's actually pretty scary riding shotgun around the track at first, even after driving it myself for some time. I was happy to note that his speed through a few of the turns was a good 10 mph slower than mine, and he was really pushing, although we did have an extra person in the car. The largest difference I noticed between the Evo and my GSX was in braking.
I never had a single brake issue the entire day, the R4-E pads always worked 100%, and never had any fade whatsoever or any fluid boiling. My brakes did get VERY hot, though. The caliper paint (bad idea) started to bubble and turn black on the edges, and I discovered later that I cracked a brake piston boot from the temperature. The difference I noticed is that the ABS kicks in _much_ later on the Evo, and when I get back onto the track in my GSX, I realize the ABS is really holding my braking back. I decided I would finish the day with it on, and next track day I'll be sure to disable it. Almost every turn I would be on the ABS, and I know I can brake harder with it disabled.
In the end, I had about 150 miles on-track time, 80+ laps, and averaged 7.3 MPG. Most of my rear bumper was covered in dark brown exhaust soot, and my friend had to write a message in it :coy: (pic below) . The muffler tip also turned a permanent golden brown from the heat and countless flames shot out the back, I think it actually looks better now. :cool:
For the next track day, I will be sure to have the camber where I want it, which will probably end up being 2.25 front and 1.25 rear, and have the ABS disabled. I hopefully will also have my Toyo RA1 tires, in the 235/40 flavor to play with. I still haven't decided if I dare to run those on the street as well. If not, I would have to mount/dismount tires before every track day, as I can't afford 2 sets of nice wheels like the Evo guys can! I'll also have my better spring rates. Together these things should make the next experience even better.
Overall, I was really impressed with the way the car performed. Not only did I not have any overheating (coolant and brakes) or oil consumption problems, but the car handled very well. I was pushing hard the whole time, 9/10-10/10. It was easy to predict (except for the left turns), and was pretty neutral on the track. I also didn't feel the tire's grip fall off as they got hot, must be a good compound. They did chunk, though, which is normal for a sticky steet tire that isn't shaved. I'm already excited about the next track day, July 7th once again at Streets of Willow. Guys, get out there and road race those DSMs!
Below are a few pictures, my favorite being the Evo right behind me in Super Evo Tricycle Attack Mode!
Great read...:D
I love the picture of the EVO running on three wheels while your car is totally set into the turn. I've run the big track at Willow several times but never the Streets and I hear it's a total blast and very technical. As far as your car overheating is concerned, just wait till July when it's over 100 degrees out there and 120 on the track :p
Hey what about me and Jono? ;)
My GSX and I were out there with him, and yeah it was a blast.
There were three GSXs there, one of which only lasted about 7 laps, at which point the fuel pump wiring went foul. Beau helped fix that, only to discover that the tow truck cable had cracked the radiator :notgood:
Great pics...how many do you have?
Great pic's & write up. DSM's look awesome burning turns. :thumb: Hey Flash, go to the track asap, if it breaks, it needed upgrading anyway. :cool: Better at the track than on the street. That goes for everyone else too, being scared isn't much fun unless you're scaring yourself! :talon:
AWESOME! This abundance of DSM track cars is making me so happy. I cannot wait until DSMs turn out in massive numbers to track events. They really are one of the best cars for a weekend racer.
If only I could finish with my projects and actually GET to the track...
Awesome man. I'm glad to see the brakes held up, that's been one of my biggest concerns going into my first trackday. How many laps did you run continously? Just trying to get an idea of what issues I might see with my car.
The only reasons why I pulled into the pit was to check tire pressure, fill up with gas, or change a setting. I never pulled in due to the brakes, and I did at least 20 minutes non stop on one session, if not more. This track is known to be pretty hard on brakes. The pedal never got mushy, and the car always stopped the same every time. The only thing I noticed was that after maybe 15 minutes or so, the pedal seemed to get stiffer, as in less spongy, as if the car suddently had SS lines, but braking wasn't affected at all, and I didn't have to push the pedal any harder.
This weekend I'm going to attempt to make brake cooling ducts (just in case, next time I run at the track the air temp will probably be 100F in July) using the fog light holes and some air ducting from Home Depot (Racing). :rocks:
Thanks for the comments! :dsm:
WOW, good to see a 2G road racing :) Are you using the stock front rotor also?
Had quite a bit of overheating last year as in underhood temperature that increased so much the t-belt cover melted on the belt itself. Never saw it happen, had the 20 min session, open the hood after and saw the meltdown, no issues with the cam gear or else, pretty lucky.
Removing the front lights helps quite a bit like yours but doesn,t remove the hot air underhood. Lifting the back portions of your hood heats up the intake manifold and lets the air a bit more toward the upper portion of the motor insted of under, just a thought, no issues or icreased oil temp?
I might try a CC scoop just to help a bit. Is the 25mm sway bar a bit large or you didn'T sem to oversteer the car to much with it. I'm thinking also about that 1" sway bar of RRE.
Great pictures, great write up, you made my day. I just need a bit more motivation right now to bring it back to the local track.
Yeah, I'm using the stock rotors, they're holding up just fine. So you're saying that lifting the rear of the hood may actually be hurting? I've heard both sides of the argument, I was thinking that the air would go in thru the headlight and out from the back of the hood, but I could see how the air vortex around the windshield might actually send air back under the hood the wrong way. I didn't have any overheating problems or anything. I'll probably have a FMIC on for July 7th, and I'm going to remove the A/C and condensor as well so hopefully the radiator will still get enough flow. Plus this FMIC flows better to the radiator. The swaybar is large, but it's adjustable. It wasnt too bad. It definitely helps, but it wasn't out of control or anything. Definitely noticeable, though. I trust that RRE knows what they are doing, and that they did their homework.
BTW, nice gallery pictures, I love your car! Want to trade bumpers and wings? :D
We're racing the big track at Willow on the 8-9 of July. We'll be there the afternoon of the 7th to get setup in the garage...
:D I might have to stop by if you dont mind!
I'll definitely go up to the Streets to see you run... ;) We usually get there around 2pm and setup in the garage closest to turn nine...
Great thread! Really nice writing and pics. I just moved out to cali. a couple weeks ago. I have my car pretty much ready to road race. I just need to throw on the JIC's that I bought last fall. I also might as well pick up some track day pads from TCE. I feel like I have been building this car forever and still havn't gone to the track! Anyway, I would like to go with another DSM'er so maybe we can hook up for the drive up. What other safety measures need to be in place other than having a helmet? Do I need a jacket or anything else?
Nope, just a helmet. They recommend a harness (really helps), gloves in case, and your car needs to be able to pass tech. They basically make sure your wheels arent falling off and your pads are still ok, and make sure nothing is loose. Let me know if you want to meet up and drive there, or meet at the track, or whatever. Just sometime before July 7th. :dsm:
BTW, nice gallery pictures, I love your car! Want to trade bumpers and wings? :D[/QUOTE]
HÉ HÉ, no way ;)
MAde a change last year to the Cobra 2001 PBR calipers with 13x1.10 rotors. With R4-E pad it made a 60mph-0 in 103 feet in the small comparo you see in the pictures. Not bad for a roughly 650$ upgrade.
Try a CF scoop, might be a better choice but a bit expensive if you compare the "lifting the rear" option.
Long live the ROAD RACING DSM crowd.
The event I went to was hosted by SRT Motorsports, it was $160 for the whole day, including free instructors and a shit load of track time. Individual companies like SRT Motorsports pay to basically buy the track for a day, then make back that money by charging individuals to run the track.
jmakado said:
Also, how much does it cost?
If you want to come run the big track that weekend (July 8-9) with NASA, we should have 2 or 3 Lasers there besides Greg's. The price should be in the neighborhood of $150.00 for 1 day or $225.00 for 2 days. We'll have 2 Lasers at Willow Springs (big track) this coming weekend (5th,6th,7th).
Tom
