My First Headlight Retrofit & LED Project
CheaCheaBoy
139
Nov 25, 2004
Boston, Massachusetts
These are my first pair of ebay headlights. My recommendation for you is to not purchase them, unless you buy them for a retrofit project. Any other reasons would be garbage, because they don't perform.
I ended up using the high beam section, for my low beams. I couldn't see anything when I used the headlights with my HID kit.
This is how they would project at night. The fog lights were brighter than the high beams. I was pretty much driving with fog lights only.
So I decided to buy LEDs to update the look of my car.
This was the first design that I thought was pretty cool.
I decided I was going to take the whole headlight apart and retrofit it with OEM Projectors. I also removed the cheap halos.
Got my hands on a pair of '09 OEM BMW Projectors
I also decided to change the location of the LED. This was the brightest.
Guess what season I decided to work on these headlights???
This is how they would look in the day.
This is how they would look at night.
I am still adjusting the rotation on the projectors. The cutoff is off, but the light output so far is more significant than it was originally. I am going to redo it, once I get my hand on another set of projectors (4 total).
Opinions?
I think that they are looking pretty good. Where did you get the LED strip at.
I let you know once I get my interview from my recruiter ;). If I get the combat simulator officer position, I'll send you a pair :pray:
Looks good minus the bumper. The struggle for lighting solutions is very time consuming eh
I know I am not a fan of the bumper either. I am trying to make a custom lip or buy a new one. Lighting solution is definitely and arm and a leg, but the work is worth it.
Light output of those projectors isnt that great. I have a set of TSX with clear lenses and they are way brighter (4.3k bulbs).
The TSX with the clear lenses is a great combination. That's what I try and use whenever I make a set. There's a couple of tricks you can do to help sharpen the cutoff but the overall light output is (IMHO) the most important part.
Bold = the truf
The cut off is nice but I rather have more light on the ground/road. Ultimately that is what matters while driving at night. :D
You know the TSX Projectors is the best one out there especially if you put the clear lenses. But I just did this retrofit because it cost me about $150-200. I am waiting on the s2000 type r :pray:
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
