2G My Engine blew up!
ryancampbell98
118
40
Mar 24, 2023
Wildomar, California
What went wrong? Go easy on me. Constructive feed back welcomed. I’m still very new.
To give context my engine is stock. Stock bottom end, stock head. I heard from a lot that these stock blocks can handle 300hp easy and can be maintained safely. I did an Evo 3 big 16g with ALL supporting mods. I mean ALL SUPPORTING MODS. Did not cheap out on this one at all. Got it tuned by someone who is very reputable and legit. His goal was to keep the car safe and reliable and recommended that I not push the car too far knowing the engine has 200k miles and stock block etc. On E85 the car threw down 308hp on 25psi on the dyno which I was happy with and we didn’t wanna push our luck anymore, so we kept it simple. Not even 30 minutes later my engine goes bye bye on the highway pushing 80mph 18-20ish psi. Oil pressure shot down and smoke everywhere There was a piece of the block I’m assuming on top of the valve cover which leads me to believe it’s more than a blown head gasket.
I do have the 96’ 7 bolt which is one of the worst and 200k miles so if that’s the reason I wouldn’t be surprised. Had an oil analysis done and had the engine looked at and there were no signs the engine was read to go. Should I rebuild a stock engine with less miles? Or just go fully built engine?
