GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
Price breakdown for the curious:
stainless:
3" ebay DP $50
Alumized steel:
two - 3"x5ft and 1 - 2.25" j bend $70
two 3-hole, 2.25" flange $10
one 2-hole 3" flange $10
one 3-hole 3" flange $5
Need to buy:
DMH cutout $180 new or cheaper used if I can find one used...
Not bad, "full exhaust" (oem muffler/dump) for <$330.
I was toying with the idea of dunping the exhaust at the downpipe... Well I tried to mock up the dump, And I was never satisfied with fit, or potential heat/exhaust damage...
So I made a turboback (w/ ebay DP, $50 for DP is cheaper than even the raw steel to make it)
I used a shitty $90 HF flux wire feed welder w/o sheilding gas. Needless to say the welds suck and are very labor intensive. Im still chasing down leaks, but Im almost done.
The Main idea is to have a straight 3" tube all the way back, and dump right under/behind the rear axle (once I get a dmh valve, I will weld the flange on... till then I sealed it off, b/c I'd rather not mock it up w/o the valve). then the last <2ft are factory-ish 2.25 and I reflanged the muffler to a 3-bolt universal If I decide to go aftermarket later. I prefer stock quietness for now.
I eventually plan on lowering the car, but As it sits... I seem to not have clearance issues. The lowest part is 3.5" (bottom of 3" straight pipe).
I didnt make this a tech article because Im looking for feedback, since this is my first attempt at an exhaust. Please keep criticism CONSTRUCTIVE. Im not sensitive or anything, but useless comments are, well, useless...
Ive also never really seen it done this way and wondering if there is anything terribly wrong with running it under the diff. (or anything I did in general) anyone ever scrape that area of an exhaust?
stainless:
3" ebay DP $50
Alumized steel:
Need to buy:
. I dont care what it sounds like, as long as WOT is evil, and cruising is dead silent. Mission accomplished.
