2gdsm_nc
- 136
- 1
- Oct 24, 2002
Elkin,
North Carolina
Ok not a blog, just some questions.
OK I've been slowly building this motor for 2 years and it is time. The motor is done, (well almost, you tell me) I can tell cause all the empty parts boxes laying around, instead of being full
specs:
BOTTOM END
2.4 4g64 yes 7bolt
no worries
ACL Race tri-metal bearings Mains/rods 1pc thrust bearing, had no choice, thats what the block was.
Crco cap kit, on ARP mains, Was honed
Eagle Rods CRS5900MB3d
Wiseco coated pistons K548M87's
Plugged holes in block using Allen head NPT plugs, So I tapped the holes.
New mitsu water pump
Forward facing oil filter housing MD189888
New Oil Pump and Front case, BSEK installed Mitsu stub shaft w/Oil ring
New Tensioner and Mitsu timing pulleys.
Gates T256 Timing Belt
Have the stock damper on it, would like a fluidampr...
TOP END
1g head
Fidanza 961996 adj cam gears *RED*
ARP head studs 207-4203
BC 280* int. & Exh. Cams
Ferrea exh. valves F6054 Int. Valves F6052 1mm over
Crower Springs & Retainers CRO-84175
Fel-pro stem seals ss 70359
Bronze guides
ICS Titan Head gasket S92754
Give it a shot.
Had the valve cover & Oil Pan bolt holes timeserted so now they are 6mm steel threads!! If only I could afford the 8 and 10mm for the exhaust holes.
TRANS
Untouched 5 speed
quatermaster dual clutch _NEED FLYWHEEL FOR IT!
Well new U-joints, and shifter bushings
TURBO & EXHAUST
14b now....
But have this and yes a alt relocation kit. turbo going on the 2.4 i dont know yet
Fuel
880 Precision injectors in a box....042-0880
wally 255 highpress. to stainless -6 lines
sx filters x2 1 stainless screen one paper
sx fpr
Air
K&N
Dejon Blowthru UICP
Greddy RS
GM maf 3 1/2"
Custom(meaning I had to Piece it together) 2 1/2" LICP to the front mount.
1g Intake and TB new shaft seals, and faiv blockoff plate. along with egr blockoff. Yea for a '95 no emissions testing.
Nitrous
NOS Wet Kit 05131NOS
NOS RPM window switch w/3000 on and 6000 off pills in it.
Boost Pressure switch to turn off sys. when at pressure
NOS Purge kit and automatic bottle heater blanket.
Management
well...
Maft
1g CAS for timing.
Palm datalogger, on a 2g eprom ecu, I know WTF
Need the link but money ain't growing on trees yet... and they ain't handing them out for free.
But that is what my plans are to get the v3 Lite soon hopefully...
EXterior& Interior& Wheels
Stock, accept the cutting on the front bumper I had to do for the FMIC
Lowered 2" Talon Swirl wheels Painted Black. whoot
Megan short shifter, why buy the B&M its the same thing, just 100$ more.
Greddy Turbo timer, autometer eGT gauge probe in stock mani, POS narrow band autometer 02 =unplugged, annoying and pointless, MSD lazer programable Boost gauge.
Carpet stains
Sunroof carpet falling in.
Antifreeze smell, ahhh the best air freshiner, Dont leave a jug behind your seat as it will rip it open when you slide your seat back!
K now any advice. If I'm forgetting anything, as I plan on taking out the old motor soon and starting this off.. As pretty as this motor looks on the engine stand its useless sitting there huh,
Hey at least I'll have a good running motor to fall back on,
hope I won't have to though.
specs:
BOTTOM END
2.4 4g64 yes 7bolt
TOP END
1g head
Bronze guides
Give it a shot.Had the valve cover & Oil Pan bolt holes timeserted so now they are 6mm steel threads!! If only I could afford the 8 and 10mm for the exhaust holes.
TRANS
Untouched 5 speed
TURBO & EXHAUST
14b now....
Fuel
sx fpr
Air
K&N
Dejon Blowthru UICP
Greddy RS
GM maf 3 1/2"
Nitrous
Management
well...
Maft
1g CAS for timing.
Carpet stains
