Justin Lauscher
- 221
- 34
- Aug 18, 2015
Escanaba,
Michigan
SO heres my problemo, I recently installed a USED MTX-L wideband and at the same time i installed ECMlink, ive gotten idle dialed in by AFR with mafcomp so far but my problem is my gauge always reads extremely accurate, but my wideband on my log looks close on start up but then its like it looses connection. Everything is wired correctly and i just confirmed connection to pin 4. I am using the narrowband sim so it effects it pretty heavily.
Moral of the story i have the car running pretty decent for now for cruises in OPEN loop but as soon as it closes loop, (when it does) it car leans right out and runs like poop. I just hope to get some insight before i try to blame the wideband. Wideband is always reading good readings, but the ECU says otherwise.
I hooked the yellow wire to pin 4 at the ECU. Red to 12v key on, black to chassis ground. My brown wire is burried in black tape. i don't get it. im stumped. I would say its the sensor itself, but then why would the readings on my gauge still seem pretty good but just the ECU sees something totally different?
