MSD dis2
jdm93dsm
171
Jun 21, 2003
Im in search of a msd dis2 ignition.... i went to a local autozone and bought a ignition and the guy there said it should work on my car..... wrong. but this was the only ignition they had in stock. where online can i find a msd dis2? preferably somewhere where I can use a charge card and get it here asap :)
is there anything else that is required to run a dis-2 that a stock dsm might not have? does a stock dsm have 2 coil packs.... does the dis-2 really need dual packs?
I was looking at the MSD SCI... are they good? The dis-2 is rather expensive for the lil performance im looking at for my NT. is the SCI distributorless? It didnt really specify where I was reading about it, but it came off a dsm website so im guessing it would work :confused: .
According to the MSD tech I talked to, all you need to do to run the DIS-2 coilpacks on a stock ignition is the adapter (P/N 8912), though you'll probably also want to grab the coil interface blocks. If you're running it right off the MSD ignition controller, you can skip Pn 8912 and just go with the interface blocks for easier wiring hookup.
I run DIS-2 on stock coils, I use Haltech for the rest. My .02
