MSD dis-2 and coil on plug
SHEARER_TSI
531
Nov 23, 2008
Oil City, Pennsylvania
Ok my car is a 90 and I am going to be installing a msd dis-2 and a buschur cop ignition. Does it matter that my car is a 90 since the stock coils are not being used? I am horrible with wiring so if someone could help me out or has a diagram that would be great.
it doesnt' really matter unless yhou're using a bone stock ECU and ignition setup as far as i've experienced. The tach adapter however, DO NOT run it off the MSD unit, your tach will half ass work half the time. hook it to the crank signal of the CAS sensor and then it's output top the tach lead that use to run from the stock harness, this will provide a reliable and stable tach signal. Everyone I know that's ran the adapter off the MSD had their tach either not work above or below around 4K RPM and that's how i fixed it because that's how i wired mine with the hatlech before i had an MSD box on the car
Ok so since I have a cop I can disregard the stuff on that link about the coil pack correct? So do I just follw those instructions and hook up the cop as if it were the stock coil pack?
