MPG problem
Lil' Shaun
210
Nov 30, 2003
dayton, Ohio
I'm getting about 10mpg
I keep getting a code that comes and goes for fuel trim bank 1
the light usaly comes on when cruising at 2200rpm
I just checked the plugs 1&3 are lean 2 is good and 4 is rich
I have even compression and no boost leaks and nearly no mods.
P0170 is usually caused by O2 sensor but it can also be due to volume air flow sensor, injector, fuel pressure, intake air leaks, ECT sensor, intake air temp sensor, barometric pressure sensor, exhaust manifold cracks, incorrect fuel used, ECU failure.
when was the last time you changed your fuel filter? seeing as how the cylinders are seeming not evenly fueled, that's the first thing i would check. if the filter is blocking fuel a bit then cylinder 1 would get the least amount of fuel.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
