motor swaping, from 97 to 95
faulkner
191
Apr 22, 2013
spring lake, Michigan
hi, i am buying a 97 eclipse gst. it has a 7bolt and auto trans. im buying it to swap it into my 95 gst which has a 5 speed. im keeping the 5 speed just swapping the motor into my 95. never swapped a motor myself. i just bought a 8 ton cherry picker. think i can do it? what is the hardest part? since just motors are being swaped do i just unbolt mounts, wiring and trans than pull it out of the top? any tips help thank you.
this is the motor in the 97 i have to take out and put into my 95!
this is the motor in my 95 that i need to take out and put in the burn pile...LOL
Unplug your wire harness, it's easier to unbolt you ps pump am leave the line connected so you won't have that mess and have to refill it. Take your radiator unbolt your mounts and take the motor/tranny out as one. It will have to come out on an angle. It also helps to take the tranny mount plate off the tranny. If you have a load leveler that will help to to angle the motor when removing it. Then your going to have to address the cam sensor because on a 97 there on the tranny end of the head and a 95 there on the timing side of the head.
