motor swap
Still using a 6 bolt head? Actually id doesnt matter all that much, just use your 1g cas. Obviously you dont use the crank sensor, you know that. hmmm, there are differences (I THINK, not 100%)in the water temp sensors but you may be using your original tstat housing etc so that would not be an issue. I think the KS is the same.
Really dont think you have anything to do wiring-wise. You should be g2g.
