1G motor swap confusion... smh
The easiest way would be with a boost leak tester. If you search for it on here you should find multiple threads on how to make one yourself easiest way to test the whole system rather quickly.
So i checked for boost leak. None i could find.. changed all vac lines to ensure no leaks. Started car was doing same as before idle jumpin 300rpm. And will only rev to 4k. I adjusted cam angle sensor and got choppy idle to stop. Still only revs to 4k. Now when you let off gas it pops out of exhaust and car tries to die... :( i have always wanted one of these cars since they first came out.. this one is starting to make me think i didnt.. so frustrated right now.. i have no clue what to do now. Is anyone on here that knows these cars close to warren Pennsylvania.... i could only wish
    • Sdcryan1
