more timing less boost?
yo2001
323
Feb 29, 2004
Birmingham, Alabama
I'm tryin to get little bit more HP from my Talon, the mods are listed on my profile. I've been tuning little bit lately and getting to run 20 psi on 93 psi with no knock sum in 3rd gear with 17 deg of timing at 7000rpm via pocketlogger. (running conservetive 90 ECU) in the midrange, I'm getting 22-21 deg of timing. Would I gain more power by turning the boost down to 18psi and add more timing? I got 93 octane here. Thanks
If you have the fuel to support it, I would suggesting turning down the timing and adding boost.
However, your injectors look maxxed out. Try adding timing at your current boost.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
