MOORRE Slave cylinder problems.
fwdturbobov1996
1,504
8
Feb 27, 2004
Blue Springs, Missouri
Ok will someone check if the rod/boot combo has the straight rod in it. Or is theres bent. Cause this is seriously stupider than shit. Ive used 5 bottles of brake fluid, 3 BRAND NEW slave cylinders and no pressure. Everytime I bleed it I will get a little bit of pressure then it makes this werid ass sound and the slot that the rod sits in in the tranny extends out and the rod is not straight inline with the piston, so therefore, i think, it will not retract like it is supposed to. everytime i push that tranny " mount " thing back up in there and make it straight in line with the rod so it can retract. But everytime I bleed it extends out, and doesnt come back :cry: Thanks in advance
you have the wrong slave.I have a galant with a eclipse tranny.....eclipse slave(3/4 in bore)...galant slave(13/16 bore) inside diameter on both.did someone do a tranny swap? I have a galant and a talon tsi and both rods are straight if that helps.
is that even possible to have the wrong slave? Thats so ### :cry: So what is 3/4 or 13/16 bore? the rod size?
rod length=3 1/2 inches long,fwd and awd have different rods.check your clutch fork,make sure it works correctly.sounds like you are over extending the piston if the rod is bending
Its my fork.. i took the little boot off and it just fell out LOL! . Now what do I buy next and how hard is it to put a fork in? The fork is the thing the rod was resting in right?
That is not good news...you have to pull the tranny...chances are you broke the pivot ball or the throw-out bearing return clip or both.take the inspection cover off the tranny(metal plate,bottom half of tranny)this will let you shine light into the bell housing as you look through the fork hole to find the problem.Maybe you might get lucky and the fork just fell off the pivot ball.do all your home work before you pull the tranny,it might be an easy fix.use a bright light.
you might get"FORKIN"lucky LOL!
I have no idea what Im lookign at when im looking in it. I see this metal thing that I can move ever so slightly that is agains the clutch and this tiny tiny piece of metal fell out with the fork. Its about 1/2 long and its cylinder and on the ends is chipped kind of. ROFL Oh the problems.
get a haynes manual for your car at the auto parts store...it will show you pictures...sounds like the tranny has to come out...bummer :(
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
