MMCD: ECU comm error, test the cable?
tbgallant
Oct 13, 2005
Halifax,
Hey guys, I made my own passive palm logger cable for MMCD following the directoins I found on the forum (Thanks Steve). Everything seemed to go well until I tried to log, getting no signal and an "ECU comm error" using the Test feature of MMCD.
I tried moving the connections around at the ALDL connector with no luck (they are on very snug, I have the proper female fittings). I also tried reinstalling MMCD with no luck.
Is there a way I can test the logger cable I made (with a voltmeter?) It seemed to go together well and I followed the directions (pretty straight forward).
Thanks for any help.
Will post a picture this evening or tomorrow.
I'm using the Handera 330 (kinda rare, out there, but similar to a III) with OS 3.5.3.
Thanks
Keep in mind that the passive cables depend on the PDA serial port support non-standard RS232 input signaling and being able to output something close to 12v on the positive swing. This is part of the problem with Clie's.
Steve
Hmm.. well it uses a standard Palm hotsync cradle and communicates fine with the Hotsync software.
I'll try and get a picture of my cable tonight.
Thanks
