MLS Gasket: Mitsu or Cometic?
1sickgst
80
Jan 12, 2005
Sweetwater, Tennessee
Hello all. I'll be upgrading to an EVO III 16G later at the end of the summer. I'll be including supporting fuel mods as well. I don't plan on running a huge amount of boost, just enough for a fun, dependable daily driver. I'll go ahead and change the head gasket w/ ARP's as well. My question is, which brand MLS gasket should I go with? Mitsu or Cometic? I've heard lots on both. I'm just curious what to run with my setup. Thanks in advance for the help. :thumb:
I've been running Cometic for 8500 miles on 21 daily and lots of 28 track boost and haven't had any problems.
i have a mitsu 4 layer metal head gasket with arp stud on my stroker motor and haven't had any problems
I thought I would get mixed results. Another question, and I know I've read countless threads on this. Did you spray your MLS gasket?
I run a Cometic because thats what my engine builder wanted to use, I had heard about issues with the Cometic and deck + head surface finishes but haven't had any issues yet(2000miles).
To the OP, are you getting your head & block resurfaced before you are installing the new MLS gasket? I believe you will probably have sealing issues with either of these gaskets if you don't. If this is incorrect & one does normally work without a resurface, I too would like to know as I've been holding off swapping to a MLS gasket as I didn't want to pull the motor to get both surfaces refinished, just for a head gasket. If I could get away with just the head being resurfaced, that would be fine.
Another option is ARP studs with a stock gasket. This has been proven many times to hold a good amount of boost & is sorta a safety factor as if you have a bad tune & end up with lot of knock you will pop the gasket, instead of something more import. I know lots who don't have problem with 25psi on this combo & have heard of numerous who have run more. I've run 22 psi on it without any issues, for a couple summers.
I ran a cometic and I was not happy with the results I got. Ive ran a couple Mitsu MLS gaskets and never had an issue. I also use no sealant or spray when I install them.
I definitely plan on getting the head resurfaced. In the 3+ years that I've had the car, it's never heated up on me. So, I'm assuming the block will be OK. I will get it checked though, just in case. So far, I'm leaning towards the Mitsu gasket. Thanks again all.
Just resurfacing the head usually won't work and that's why a lot of people have issues. Most machinist's don't leave the surface smooth enough for a mls gasket, it has to be like glass or it won't seal.
I have NEVER had good luck w/ Mitsu gaskets...every application (both head and block were decked) they pushed coolant unless o ringed. Cometic gaskets have never given me any issues. I usually throw a thin coat of copper spray on both sides, i dont get too crazy with it though.
That's most likely due to installation, if it's done right it won't leak.
Yea, there are just too many successes w/ the Mitsu MLS head gasket to excuse it as being a bad gasket. Considering torque sequence values and surface finishing, it seams that ALL metal head gaskets are succeptible . . . or finicky to sealing procedures. That's just life runing alot of power that NEEDs such a setup.
This leads to my question. 1sickgst, do you think you need a mls headgasket to run an evo3 16g to it's limit?
overdoseheroin, take a look at this thread running now if you could: metal head gasket prep.
Do you have a mirror finish? Why are you having so much problems? Many others don't. I forgot, but what gasket are you using now?
I dont, but i have told others that i have done work on to have that done after finding out about it a while back. I have only had one mitsu gasket not push coolant, another was with an o ringed head. I currently have the cometic, and every time i have used one or used it on a car i was putting together worked flawlessly. I just prefer the cometic gaskets because i have never had any issues with them. Not sayng mitsu mls gaskets arent good, they just dont like me. LOL
I can almost guarantee that you didn't install it correctly. Why don't you explain what you did step by step.
Wow...its little elemetary to have to explain how to install a headgasket...but i will say that i just talked the kid that i did the most recent install and i was under the impression that he had decked the head...he didnt, so that would be the reason for that. Im not going to get into an argument over how i installed it because itis the correct way...i think after 7 years of building these cars i think i would have aquired the knowledge to correctly install a hg.
If that was the case, you'd be able to tell the difference between a cylinder head that had been resurfaced, and one that hadn't.
Not really, it was done a few weeks ago, but he had assembled it with a felpro felt gasket and it started to push and overheated a few times...i was just informed of this as of my last post, i called him..LOL. I didnt pay much atention to the fact becuase when i told him to have it re surfaced, he said it was...meaning it was resurfaced pre headgasket failure and the events that it overheated, on more than one occasion. I just took his word for it, thats where i failed. regardless, its due to the fct that the suface is obviously out of spec. But still, when it goes back together after it gets cut and i polish the surface, its going to be re assembled with a regular Cometic.
