Can I use a cometic mls gasket with o ringed head
shadohc
89
Mar 20, 2006
Baltimore, Maryland
I have stainless steel o-rings in the head and they are around each cylinder and I am having my motor re built and i allready bought a cometic gasket can i use that with this application or do i need a composite
I bought the car and I am doing a rebuild and bought the gasket before i tore it down should i get a oem composite or will a fel pro from advance be good i also have arp head studs
You can use a cometic with a O ringed head or block. Its been done, and there has been a couple shop cars that have ran that setup for reasons of needing a special thickness gasket since the oem mls comes in one thickness.
Who did the oring in your head? The main importance is, whats the oring protrusion?
Generally the rule of thumb is Steel oring to a composite HG and copper to MLS. You can always change out the orings for copper and run the cometic. Copper orings on a cometic or even a mitsu MLS are my favorite methods of sealing the head to the block. They seal too well, and will not forgive an error in the tune or a mishap with boost.
Composites and a steel oring seal well, but one small hiccup and it will let go at 40+psi. The mls and an oring will not.
.009 protrusion. M2 had been doing cylinder heads for Alex at Dogbox racing for years, and every motor he does is SS oring and USUALLY a oem MLS. On his evo he had problems on a non o ringed head. He had to use cometics because of the thickness he needed specially made. He has had a SS o ringed head with a cometic mls for the past 2 seasons.
There is more then a few guys that dont post there problems on here that have had sealing issues with a felpro permatorque (I just became one LOL) and had to go mls with a o ringed head.
I have 4 buddies that run the same setup oem mls and a SS o ring. Oh yeah the composite will most likely let go...a mls will push, warp the head and still have to be replaced 90% of the time. or it will just melt/destroy everything inside. Just got to keep the tune SAFE LOL.
I have a oem mls that came off a buddies car that had a ss o ringed head, never leaked a drop, and bit into the gasket very nicely. O ringed a problem block head if it does not seal without the o ring with a MLS gasket will NOT fix the issue. Both surfaces still have to be perfect for the mls and a o ring. Just be ready for everything to melt if something goes wrong.
Ma bad, I was aiming my post towards the original poster. Unless you know the info on his head, then you are spot on.
In my use, I have a buschur oring'd head. It was originally done with copper orings for an mls. I switched them out for steel rings and used felpro composites for the past 2 years. Now I am back to a cometic headgasket cause I was tired of pulling the head off due to very minor mishaps. Even with a safe tune, ironing out small bugs can get trivial. Experience builds wisdom :)
The way I was taught, and still think is, The head gasket is the fuse, when it lets go, how big a boom do you want?
A what level do you think changing a HG just becomes basic maintance?
I did my research on here and from what I got it is better to use a oem composite with stainless orings my head is a buschur oringed with oem composite
In my case, every year when the bearings, rings, gaskets and seals get inspected and/or changed. Depending on compression, blow by, oil consumption, wear, etc.,
Another reason I liked the cometics and oem MLSs with the oring'd head was because they were reusable.
I know it was, I was just adding more info in my searches, talking to people I know etc for further reference since forums are full of misinformation.
Ever do a o ring head mls gasket search on google...man different forums throw around rumors and hear so so much it makes me wanna throw up.
I am about to put a fresh head back on my new motor because a felpro mls gave on me. I know I am going to play indecisive with the oem composite, and the cometic mls I got sitting here LOL.
And Ted thats a perfect reason...cleaning the gasket! Its so give and take.
  • Wanted 6 bolt NT water pipe
    • chrisman287
