missing fuel pump bracket
Insane20
545
11
Jun 12, 2012
Natrona Heights, Pennsylvania
Ok so heres the deal, I was swapping out my stock fuel pump for an evo9 pump and when I removed the hanger assembly I noticed that the bottom of the bracket that holds the fuel pump is gone. I have no idea where it went I guess someone forgot to put it back in. So my question is can I just use a piece of metal and bend a 90 on it and put a piece of rubber under the fuel pump, bolt it up and be good to go. Or did that piece have something special on it that I cant replicate. Also I salvaged my o ring and top hat pieces off of the old pump but there was no spacer on it. Do I also need this?
Ditch the o-ring and spacer and go down to a Toyota dealership and order part number: 23239-21010. It's an improvement in every sense of the word, and it shouldn't cost more than two bucks.
Also, check the inside of your gas tank for that missing bracket.
I no I never followed up on this but I dont like threads to go unresolved. For anyone in the future that finds that someone did a hack job on there fuel pump assembly read my post at the bottom of this thread.
http://www.dsmtuners.com/forums/dsm-build-journals/474182-95-talon-6-bolt-dd.html
I basically do a step by step on how I fixed my line and attached the fuel pump to the bracket. It didnt cost much and it works great. I hope this might help someone in a bind.
  • For sale 4G63 Planetary Gear Sets ( for 1G & 2G )
    Planetary Gear Sets $175 a piece + shipping & paypal fees* fit 1G Auto GSX/GST * fit 2G Auto...
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
