mishimoto rad what coolant
Run cooler i never knew a coolant to make my dsm run cooler. Of course if it running hot the coolant isnt the problem. I guess you could try a few and see whats works for you, coolant is cheap enough.
If your cooling system is completely empty, which I'm guessing it is, get the full strength gallon and mix it yourself. That way you'll have a total of 2 gallons of fluid when mixed 50/50. I made the mistake of not filling the gst up with enough coolant and couldn't for the life of me figure out why it was still running on the hot side. Der me :p
Yes there is no coolant at all in it, so i will do that buy a full prestone coolant, and i gallon of water mix with water wetter what i can find at the auto part.
Well. I live a few hours north of you. i run 70/30 with a bottle of water wetter. I don't believe coolent brand matters, but Redline Water Wetter is proven to lowercoolent temps by ~10°
So just ran more water then coolant is it better
Yes usually running a bit more water than coolant can keep it cooler.
Yep, and the more coolant you use the higher the boiling point is. For a car that runs fairly hot to begin with, a higher boiling point is a good thing.
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
