FIBA M - EC17PSE
Supporting Vendor
- 6,752
- 5,159
- Nov 1, 2008
Orlando,
Florida
Before my oem rad (top) neck broke I was seeing temps of around 199F / 93C with the OEM rad cap,
Now I've changed to a Mishimoto rad and HKS 1.1 psi rad cap temp is going to 210F / 99C thats the highest im getting. fans seem to kick in later then normal, it use to kick in about 199F now its not kicking in till at least 210F ish? now I have oem fans and there both wired up to come on at the same time as I no longer have AC so I have no condenser radiator , cruising is about 192F and ive not pushed the car yet so I don't know them temps just yet!
So could the issue of running the 1.1 psi rad be making my temps rise a little more then normal? as is 210F anything to worry about, my mix is as close to 70% water and 30% coolant as I could get it,
while on the subject of rad caps, I cant find an answer to this question!!! I know they create more pressure but will that pressure aid in a head gasket failure? I just want to know as if it does then it will be replaced with the OEM rad cap again
