- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- 650 injectors, tdo6 gt3071r turbo, fp mani, hks down pipe, no cat, hks full exhaust, 1g tb, after market full fmic 3in core, kn filter, mbc hallman, ngk wires, home made catch can from home depot, mish rad heat shroud with slim fans and thermostat 140, and lower and top rad hose, turbo blanket, fp manifold blanket, 2g o2 ported housing. Act flywheel, act cluch kit.
- Mods-Engine
- Supertech beehives spring retainers, Ferrera over size valves, 5 angle Job, kelford 272, stage 3 port, turbo ported,
Wiseco 9:1 pistons (.02 over)
- Eagle H-beam rods
- Clevite bearing
- ARP studs & bolts
- Balance shafts eliminated
- Micro-polished crankshaft
- Balanced, Blueprinted with engine spec sheet and HOT Tanked to strength the steel up
- Mods-EMS & Logging
- blue greddy e-management no tune cable, boost control,
Aem wide band
- Mods-Drivetrain
- red line mt90 on trany, royal purple on diff & trans x
Lsd, act kit
- Mods-Handling
- megan street coilovers 32 damping, 17x9 5zigen zr+520, drilled slotted front rear disk.
- Parts Wishlist
- Dsmlink, aem meth kit, 1400 injectors, new paint, fiver hood, big brakes, thermo exhaust
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
