2G MFI/MPI relay failing?
HaveBlue83
660
245
Feb 10, 2009
Wrightsville, Pennsylvania
My MPI started acting up on a perfectly driving car, my 95 Talon.
After 10sec running it starts clicking and the boost gauge (setup for temps) goes all high up and the CEL cycling doesn't complete, then the car dies.
Turning the car to ACC, the boost gauge goes up then down then jumps around after a few sec.
i believe my MPI is failing.
FWIW my MPI has passed the FSM checks
onto the MPI supply wiring ..
Good, the relay itself isn't high on my list of failing items. I find it more likely that a grounding, system voltage, or ECU damage is the underlying issue.
Since it sounds like reproducing the failure is easy I'd watch the main power to the relay and the signal from the ECU to activate the relay. Make sure the system voltage stays above 12v and that the pin from the ECU stays close to ground while the engine is running.
Make sure none of the ECU capacitors have leaked.
ecu looks mostly decent, some of the protective coating is failing. i have a spare ecu. car now starts and runs, of course, in typical DSM fashion
might just swap the ecu, i think it might be in need of service
    Used Autometer Z series 52mm electric oil pressure gauge. Incluses sender, bulb socket, and...
  • For sale 2g DBW Setup/EVo3 Manifold/ DBW TB
    Have a full DBW setup that was used for a few days, going back to cable but can offer a discount...
    • Bedicine
  • Wanted LF 1990-1994 Mitsubishi Eclipse GSX
    Looking for 1990-1994 Mitsubishi Eclipse GSX for a project car.
    • Izaier
  • Wanted 2G turbo parts
    Looking for a few misc parts for a 2g turbo. Radiator support, front corner of driver rear wheel...
    • JMN95AWDTSI
  • For sale 4G63 OEM 6 Bolt Crankshaft ( uncut )
    OEM 6 Bolt Crankshaft $300 + shipping & paypal fees* crank is uncutYou must be registered to...
