Meth injection injector placement question???
I don't like it. There's not enough time for the Meth to spread out and atomize. You'd be better off mounting it before the TB in the uicp.
I know what you mean, The #4 runner is right there. I ordered the snow kit and I am waiting for it to come. Do the nozzles have nuts? Or just drill and tap to install? I cant find anything on it. I am pretty sure my tb elbow is too thin to tap.
you can tap a intake pipe no problem. you want it at a minimum 4 inches before the tb. 6 is better for atomization and cooling
I haven't tried tapping the elbow before, but I would probably weld in an aluminum bung instead.
BTW OP have you read turboglenns' results on meth injection? Pretty interesting stuff.
I have given it some thought, And not only is it too short of a distance for the mixture to vaporize and burn, There is also vacuum in the manifold which can suck the water from the line.
Has anyone else gotten the snow stage 1 kit? I can't find out which two nozzles come with the kit. I would love to know! Thanks,
-Dave
