Rst303
- 0
- Aug 2, 2010
Frederick,
Colorado
i was wondering if someone could guide me i recently installed a megasquirt in my 1996 eclipse rs 420A fully built turbo i for some reason cant get the ecu to communicate with my laptop i downloaded the correct software i am using the symtec labratories complete 420A megasquirt ecu it comes with the usb to serial adapter, ecu , harness and alternator voltage regulator it is the megasquirt ms2/extra version 2.1.0 on a v3 board i open megatune connect the serial to usb with my laptop and it wont communicate something to do with the comm port ive went to file went offline then go into the communications then settings again and tried to test every single comm port all 99 of them and no luck what could be wrong im about to burn my car if i cant get it to work with this ecu
the car runs when i crank it over but i know its bad since im not getting to monitor things to tune it some one help i pmed bulletdsm maybe he will reply but if anyone can help it would be apreciated thanks
