Megan downpipe leak
wags122
81
6
Jan 19, 2005
Snohomish Co., Washington
I have the megan down pipe with the clamp and slip joint and its leaking at the slip joint I was wondering if anyone else has had this problem. And if so how did you fix it. Thanks.
I'm not too familiar with the slip on flange, mine is a 2-bolt, but you could probably use an exhaust band clamp to cover the whole slip joint and eliminate the leak. A few pictures might help also
I have the same downpipe as you. And i'm currently trying to install mine myself, but it seems to be 2-1/2" too long. Did you get a band clamp with it? You should have one that came in the box. I'm guessing yes since you wrote clamp in your paragraph. Have you tried sliding the clamp around and then tighten? Maybe it will seal better one end of the slip pipe than the other? By the way, if your going under your car to move the clamp could you measure your down pipe length for me please?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
