mechanical oil unit
I would recommend getting a SS line. Mine works great. Read stories of the regular line breaking and decided not to chance it at all. :)
i bought an autometer mechanical oil pressure gauge. I know people say to tap it from the back of the block, but will the tubing that comes with the gauge stand up to the heat that is produced by the engine? If not what tubing should i use??
Your best option is probably going to be a SS braided line, but I have never had a hose bust on me and I am running a few non-braided lines for oil... Of course I have read about people running into problems, so it's all up to you (and your budget).
Well you can always just run the line that came with it and make sure you keep an eye on it for a little while. Like after you drive around (highway or spirted driving) pop the hook and check the condition of the line. Keep an eye on if for a week or two, then eyeball it periodically after that to make sure it is holding up good. Is the car at the track often or more of a daily driver. I would think the first would be a lot harder on the car, and would increase the wear and tear on the line.
