mbc problem install need help
91gsdohc
1,099
Jan 25, 2010
around, Connecticut
i just got a mbc looked up how to install but im running into a problem and i need to know if im trying to put it in the right place im trying to put it up in the left where you see those 3wires connected
<a href="http://www.flickr.com/photos/50529416@N08/5575234560/" title="IMG00102-20110330-1631.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5179/5575234560_5ca7c252a6.jpg" width="500" height="375" alt="IMG00102-20110330-1631.jpg"></a>
<a href="http://www.flickr.com/photos/50529416@N08/5575235420/" title="IMG00103-20110330-1631.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5292/5575235420_7acbcdbd49.jpg" width="500" height="375" alt="IMG00103-20110330-1631.jpg"></a>
if any of you have pictures of how yours is that would help any info would help thanks
i have a 91 eagle talon tsi awd
That gauge will work to set your MBC to whatever boost you plan on running , but if i were you i would get a different autometer gauge that reads vacuum so you can tell if your car has any boost / vacuum leaks . I personally dont like that boost gauge but if you plan on hooking up to your car make sure the gauge is reading 0 before you set your MBC .
i only got that to set my MBC but now i dont know if i can adjust it, i was driving today (i have the mbc in but all the way loose) and i belive im hitting fuel cut. but i have to get a T and see if the gauge works.
also cant i set the controller with the gauge even if it doesn't sit at 0, couldnt i just use where it sits as 0?
attachment.php
This is like the 3rd way iv seen this done...LOL one person says the arrow faces the acuator.. another says from the j pipe to the boost controller, from the boost controller to the middle nipple of the 3way.. and the arrow to the acuator and the other end vents...
:banghead:
