Maybe knocking need advice
volcomsnow245
492
May 4, 2011
chicago, Illinois
Hey guys I was reading a thread earlier and thought that it might be happening to me and I don't know. Well I'm running 14 psi on stock fpr, a walbro fuel pump, and stock injectors. I'm worried that I'm knocking because of the fuel issue I'm going to buy a logger soon so I can tune with my safc but do any of you guys know if I should watch out for anything before I end up damaging my motor. Should I be adding fuel since I've turned up the boost and I was told by ams to keep the wideband in the 11's.
thanks.
The different between a 11.0:1 AFR and a 11.9:1 AFR is the difference between the pistons melting or not, I'm pretty sure AMS didn't just say "keep it in the 11's."
Check base timing to 5* at idle and give it a SOLID boost leak test. Once you've done both of these things, tune the car for a 10.9~11.1:1 AFR's on the WB since the stock fuel injectors should have no problem taking the 14b to 15psi with the Walbro in the tank.
:dsm:
:dsm:
Exactly. Taking it any higher and you're taking your engine to the edge.
There is nothing wrong with a mid 11 afr. I ran 11.5-11.7 for 3 years on 23psi on my old 16g talon no knock.
Lucky for you, but that doesn't make it right.
  • Wanted 6 bolt NT water pipe
    • chrisman287
